Tang Band 25-2234S 1" Hi-Resolution 40k Aluminum / Magnesium Dome Neodymium Tweeter 4 Ohm
With smooth response and low distortion all the way up to 40,000 Hz, Tang Band's 25-2234S tweeter gives designers an affordable option for use in systems that meet the new high-resolution audio standards.
- Delivers flat response from 1,000 Hz up to 40,000 Hz to reproduce even the finest details
- Integrated faceplate protects the fragile diaphragm
- Compact 1.88" square faceplate for use in even the smallest systems
- Aluminum/Magnesium dome has excellent damping properties
- This item available through special order only. Minimum order quantity is 50 pieces
We'll send you an email when Tang Band 25-2234S 1" Hi-Resolution 40k Aluminum / Magnesium Dome Neodymium Tweeter 4 Ohm is back in stock or available for preorder.
