  • Talent Y35Q203 3.5mm Stereo Male to Dual 1/4" TS Left / Right Male "Y" Adapter Cable 3 ft.
Talent Sound & LightingPart # 240-9460
Model: Y35Q203
What if you could play music from your mobile device to the PA or your powered speakers without having to use an unwieldy series of adapters that always become lost and degrade your sound quality? Now you can, with the Talent Y35Q203 adapter cable. The 3.5 mm male end fits your mobile device, and the two 1/4" male plugs feed your sound system.
  • 22 AWG conductors
  • 3.5 mm TRS male to dual 1/4" L+R male
  • 3 ft. length
Your Price: $5.29
Save $2.70 (34%)
28 In Stock
We'll send you an email when Talent Y35Q203 3.5mm Stereo Male to Dual 1/4" TS Left / Right Male "Y" Adapter Cable 3 ft. is back in stock or available for preorder.
Order in the next 0 hr 51 min to ship today. Details
More and more often, entertainers, instructors, and presenters of all kinds are turning to cell phones, laptops, tablets, and other mobile devices to provide background music, workout playlists, and so forth. What if you could do this without having to use an unwieldy series of adapters that invariably become lost and degrade your sound quality? Now you can, with the Talent Y35Q203 adapter cable. The 3.5 mm stereo plug takes the stereo signal from your mobile device, and splits it out to the 1/4" mono plugs, L+R.
NOTE: The typical "red = ring = return = right" wiring standard is incorrect on this cable. The ring of the stereo connector is actually wired to the WHITE end. Most applications will not be significantly affected. If your application does require "red = right," simply use tape or heat shrink, or otherwise mark your way to victory. Take advantage of the sale price while they last (which won't be long)!
BrandTalent Sound & Lighting
ModelY35Q203
Part Number240-9460
UPC848864023465
Weight0.25
Cable Length3feet
Cable Type3.5 mm Y Adapters
Jacket ColorBlack
