  • Talent TIP-FS5 Foam Replacement Tips for In-Ear Monitor IEM Earphones Earbuds - 5 Pair Small
CLEARANCE Talent TIP-FS5 Foam Replacement Tips for In-Ear Monitor IEM Earphones Earbuds - 5 Pair Small
Talent Sound & LightingPart # 233-174
Model: TIP-FS5
Talent's foam eartips are designed for the DCD-02 in-ear monitors, but also make great replacements or upgrades for a wide variety of other popular earbuds from Westone, Shure, and many others with a 3 mm nozzle.
  • Five pair of rebound foam replacement eartips
  • Recovery foam conforms to the precise size and shape of your ear
  • Provides a superior seal for maximum isolation and clarity
  • Designed for Talent IEMs, also fits many other earphones with 3 mm nozzle
CLEARANCE $1.40
MSRP: $9.99
Save $8.59 (86%)
50 In Stock
We'll send you an email when Talent TIP-FS5 Foam Replacement Tips for In-Ear Monitor IEM Earphones Earbuds - 5 Pair Small is back in stock or available for preorder.
Talent's eartips are designed for the DCD-02 in-ear monitors, but also fit a wide variety of other popular universal-fit earbuds from Westone, Shure, and many others with a 3 mm nozzle.
Talent foam replacement tips generally provide a better seal, and a more accurate custom fit than most silicone tips. There is a bit more of a process to inserting foam tips correctly, but many listeners in general, and performing musicians in particular, prefer the increased isolation and bass response provided by the improved fit.
Fits: • Talent DCD-02 • Shure SE110, SE112, SE115, SE210, SE215, SE310, SE315, SE420, SE425, SE530, SE535, SE535LTD, SE846 • Westone Adventure Alpha, UM 1, UM 2, UM 3X; UM PRO 10, 20, 30, 50; Westone 1, 2, 3, 4, 4R; W10, W20, W30, W40, W50, W60; AM PRO 10, 20, 30 • Klipsch Custom 1, 2, 3; Image e1, S3, S3m, S4, S4A, S4AII, S4i, S4iII, S4i, Rugged, S5i, X4i, X5, X6i, X7i, X10/X10i, X11i, X12i, X20i, XR8i, ProMedia, Reference, S41, R6i, R6m • Harman Kardon EP 710, 720, 730 • Brainwavz B2, B100 • Beyerdynamic Byron BT, BTA • Denon AH-C250, AH-C400 • Ultrasone IQ, Pico, TIO • Yamaha EPH-M200 • And most other universal-fit earphones with a 3 mm nozzle.
Dimensions: • Small: 0.44" dia. x 0.42" (11.2 x 10.7 mm).
BrandTalent Sound & Lighting
ModelTIP-FS5
Part Number233-174
UPC848864044316
Unit of MeasurePackages
Weight0.02
