  • Talent QRKS Quick-Draw Double-X Keyboard Stand with One Hand Trigger Quick Release
CLEARANCE Talent QRKS Quick-Draw Double-X Keyboard Stand with One Hand Trigger Quick Release
Talent Sound & LightingPart # 233-074
Model: QRKS
Make your mark as the fastest hand in the West (or anywhere else) with the Talent Quick-Draw double-braced X-style keyboard stand. The unique one handed quick release trigger mechanism makes setup, tear-down, and adjustments quick and easy.
  • Ergonomic trigger quick release
  • Heavy duty 1" tubular steel construction
  • Six height/width positions, also locks closed for storage and transport
  • Adjustable feet for leveling
Talent Keyboard Stand and Bench Bundle
Price: $79.98Part # 233-073
See all items in Keyboard / Mixer Stands
We'll send you an email when Talent QRKS Quick-Draw Double-X Keyboard Stand with One Hand Trigger Quick Release is back in stock or available for preorder.
No more fussing with knobs, nuts, or handles that seem to be just out of reach when you need to get set up in a hurry! A simple squeeze of the Quick-Draw's trigger just below the keyboard support arm provides easy set-up, tear-down and access to six height adjustments on this heavy duty keyboard stand. One-inch tubular steel construction ensures the Quick-Draw won't let you down when it's all on the line, and each of the rubber feet on the base feature an adjustable "bump" which allows you to easily level the stand on less-than-perfect stages or slightly uneven surfaces, with just a simple twist of wrist. The six height and width positions and ample weight capacity make this stand a great fit for virtually any keyboard, synthesizer, or music workstation, as well as many mixers and other gear you may need to have close at hand on stage. The Quick-Draw also locks in its closed position for transport and storage, so it won't fly open unexpectedly. With Talent's unbeatable value, you'll also have a fistful of dollars left in your pocket. What more could you ask for?
Specifications: • Stand height and width positions (H x W): 37" x 13.5", 35" x 18.5", 31" x 24", 27" x 28", 22" x 32", 16.5" x 35" • Collapsed length: 39.5" • Base arm length: 18" • Keyboard support arm length: 16" • Weight capacity: 130 lbs.
BrandTalent Sound & Lighting
ModelQRKS
Part Number233-074
UPC848864007021
Weight11.05
