  • Talent MUS-2 Tripod Music Stand with MSL-22 Clip-On LED Light Bundle
CLEARANCE Talent MUS-2 Tripod Music Stand with MSL-22 Clip-On LED Light Bundle
Talent Sound & LightingPart # 233-1020
Talent's Tripod Music Stand and Clip-On LED Light Bundle is the perfect combo for all music performing needs. Talent's MUS-2 music stand is great for pro audio professionals and performers on-the-go. The Talent MSL-22 clip-on dual LED music stand light provides musicians and engineers with dual intensity lighting coverage to read scores or adjust mixing console controls in the dark.
  • Stand featuers collapsible design with removable desk for portability and adjustable height
  • Stand has a folding tripod base for superior stability
  • The light's clip-on dual LED lighting perfect for music stands, front of house mixing, or private reading
  • Two LED heads mounted on flexible goosenecks with independent dual brightness intensity and can be clamped to surfaces up to 1.5" or sit on a flat surface
  • The Light is powered by 3 AAA batteries (not included) or USB (included)
CLEARANCE $21.49
MSRP: $23.99
Save $2.50 (10%)
Out of Stock
Estimated back in stock 2/27/2026
Versitile Music Stand
For performers who travel, nothing beats Talent's MUS-2 tripod music stand with detachable desk. The adjustable height is great for artists of any height, and the tripod base offers superior stability. For simple and quick set-up and tear-down, the desk removes and the stand collapses down to a length less than 25" for portability. Black finish is used throughout for an appearance that disappears into the background. Five-year limited warranty.
Specifications: • Stand height (from floor to desk lip): Adjustable from 27" to 44" • Tripod base diameter: 27" • Collapsed length: 24-7/8" • Desk dimensions: 19" W x 13-1/2" H (2" D desk lip) • Desk angle: Adjustable from 0° to 90°.
Bright Music Stand Light
Talent's MSL-22 clip-on LED light has four different brightness levels (high/low on each head) to ensure proper lighting for reading scores or making mix adjustments. Each LED head is mounted to a 6.5" flexible gooseneck so you can provide illumination coverage where you need. The MSL-22 is powered by either the included USB cable or 3 AAA batteries (not included). The MSL-22 can be clamped securely to almost most any flat surface up to 1.5" thick or sit on a flat surface.
BrandTalent Sound & Lighting
Part Number233-1020
UPC848864060422
Weight7.7
