  • Talent MS-1C Heavy Duty Steel Base Single Hand Microphone Stand
Talent Sound & LightingPart # 233-003
Model: MS-1C
The MS-1C microphone stand by Talent features all-steel construction to give you the absolute ultimate in durability and stability. The one-handed quick-grip clutch mechanism ensures that it's quick and easy to make height adjustments, even in the heat of the moment, so you can focus on your performance.
  • Stout all-steel construction
  • 360° gasket on base for maximum stability
  • User-friendly one-hand clutch
  • Adjusts from 39" to 67"
Your Price: $28.98
Save $15.01 (34%)
We'll send you an email when Talent MS-1C Heavy Duty Steel Base Single Hand Microphone Stand is back in stock or available for preorder.
Are you tired of mic stands that fall flat on their faces (not to mention your expensive mics) with the slightest bump or breeze? Look no further than the Talent MS-1C for instant relief. With beefy all-steel construction, this stand is buit to last, and the ingenious 360° rubber gasket on the base makes it incredibly stable, unlike typical cast base stands with three "feet." The squeeze clutch mechanism makes height adjustments super quick and easy, requiring only one hand to operate, so there's no fumbling with pesky knobs or collars on stage. A rugged black powder coat finish is used to keep the audience's focus on your performance, not on the gear, and two cable management clips keep microphone cords out of the way for a trip-free performance. Limited five-year warranty.
BrandTalent Sound & Lighting
ModelMS-1C
Part Number233-003
UPC848864017747
Weight9.4
