  • Talent MP112 RGBW LED Mini Par Stage Light 12 x 1W
CLEARANCE Talent MP112 RGBW LED Mini Par Stage Light 12 x 1W
Talent Sound & LightingPart # 244-523
Model: MP112
The Talent MP112 mini PAR utilizes 12 bright 1 watt LEDs (3R, 3G, 3B, 3W) to produce brilliant color splashes while remaining compact and lightweight in size. With built-in programming such as auto-run, sound active, slave control, and strobe, the MP112 delivers dazzling light shows right out of the box. For further control over essential functions, the MP112 is also compatible with universal DMX 512 protocol to use with controllers. The small footprint of the MP112 makes it perfect for lighting rigs in clubs, mobile shows, concerts, presentations, and conference rooms.
  • 12 bright 1 watt LEDs (3R, 3G, 3B, 3W) produce a vast color mixing palette
  • Easy to program with auto-run, sound active, slave internal modes
  • 8 channels of DMX gives you precise control over light functions using a standard DMX controller
  • Compact size is ideal for mobile applications in which traditional, larger fixtures won't work
CLEARANCE $19.98
MSRP: $44.44
Save $24.46 (55%)
We'll send you an email when Talent MP112 RGBW LED Mini Par Stage Light 12 x 1W is back in stock or available for preorder.
This item is no longer available
Talent has engineered high-performance capability to fit into a compact, lightweight enclosure. The MP112 features 12 one watt LEDs to produce vivid color splashes and dazzling lighting effects perfect for clubs, stages, event centers, and conference rooms.
Vast Color Palette Options
The MP112 mini PAR uses 12 LEDs (3 red, 3 green, 3 blue, 3 white) to produce a wide array of color options. With smooth dimming and color mixing options, the MP112 delivers vivid color splashes that provide great coverage for small to medium stages or rooms.
Precise Control
Wheter you are looking for a simple plug-n-play lighting option that produces a professional show or for precise control over functions via DMX, the MP112 is the perfect fixture for you. With internal, built-in programs such as auto-run macros, strobe, static colors, sound active, and master/slave, the MP112 can provide a great show out of the box. If you are looking for more precise control, the MP112 also features eight channels of DMX compatible with universal DMX controllers. From the mobile entertainer to professional touring lighting director the MP112 adds excellent value to any lighting rig.
Compact Size
The MP112 packs many features into a small footprint. The compact size of the MP112 makes it a great addition to any portable rig. Light in weight, the MP112 is easy to set up night after night.
Great Utility Light
Packed with functions and features, the MP112 is a great utility light and adds value to any lighting rig. The MP112 is suitable for both being used as the central fixture in small setups and as a fill light for larger installations. Add high-quality lighting to your rig without taking up much space with the MP112.
LEDs: 12 x 1W (3R, 3G, 3B, 3W)
DMX channels: 8
Modes: DMX 512, master/slave, auto-run internal programs
Programs: Static color, strobe, dimmer, gradient, fade, jump
Lumen ratings: 710 R, 1140 G, 890 B, 920 W, 3500 RGBW
Color mixing: RGBW (mixing color)
Control panel: LED display
Control in/out: 3-pin DMX in and out connectors
Power consumption: 15 watts
Dimensions: 4.75" L x 4.75" W x 3.5" D
Weight: 1.3 lbs.
BrandTalent Sound & Lighting
ModelMP112
Part Number244-523
UPC848864057217
Weight1.05
DMX-ControllableYes
Light TypePAR Can Style
