  • TOGGLER SP SnapSkru Drywall Anchors with Screws 50 Pcs.
TOGGLERPart # 080-303
Model: SP
The TOGGLER® SnapSkru® anchor is the most technologically advanced self-drilling drywall anchor ever and outholds the competition by 80%! The SP SnapSkrus are designed to work with #6, #8, and #10 screws up to a maximum length of 1-3/4". Tensile strength is rated at 135 lbs. for 5/8" drywall.
  • Holds up to 135 lbs. securely on 5/8" drywall—outholds the competition by 80%
  • Ideal for shelving and lighting fixtures
  • Works with gypsum board, drywall, and wallboard
  • Includes #8 x 1-1/2" combo head screws
Your Price: $9.92
MSRP: $16.99
Save $7.07 (42%)
1 In Stock
We'll send you an email when TOGGLER SP SnapSkru Drywall Anchors with Screws 50 Pcs. is back in stock or available for preorder.
The TOGGLER® SnapSkru® anchors are the most technologically advanced self-drilling drywall anchor ever and outhold the competition by 80%! Simply screw the SnapSkru anchor into drywall with a #2 Phillips screw driver until flush, insert and tighten screw until you hear a "pop", and you're done! The built-in "positive stop" resists over-drilling, and the unique locking action resists shock as well as vibration. A SnapSkru anchor won't destroy drywall either removing the screw leaves the anchor in the wall for future use. SnapSkru anchors work with gypsum board, drywall, and wallboard.
The SP SnapSkru anchors are designed to work with #6, #8, and #10 screws with a minimum thread length of 1-1/4" plus the thickness of the item being anchored. Ultimate tensile load is rated at 57 lbs. for 3/8" drywall, 79 lbs. for 1/2" drywall, and 135 lbs. for 5/8" drywall. Ultimate shear load is rated at 108 lbs. for 3/8" drywall, 149 lbs. for 1/2" drywall, and 178 lbs. for 5/8" drywall. Industry safety standards recommend 1/4 of the ultimate load per anchor. SP SnapSkru anchors feature a head diameter of 0.6" (16 mm). Package includes 50 SP SnapSkru anchors and 50 #8 x 1-1/2" combo head screws.
BrandTOGGLER
ModelSP
Part Number080-303
UPC036296551001
Weight0.88
