  • T-Amp Tripath TA2024 2 x 15W Audio Digital Amplifier Board
CLEARANCE T-Amp Tripath TA2024 2 x 15W Audio Digital Amplifier Board
Parts ExpressPart # 320-600
The T-Amp revolution continues here! This compact stereo amplifier based on the Tripath TA2024 chip outputs 2 x 15 watts and is perfect for building into audio projects or use as a standalone amp.
  • Pre-assembled, pre-tested for easy project integration
  • Class T fidelity and energy efficiency
  • 2 x 15W continuous power, adequate for most speakers
  • Requires only 12 VDC 2A
  • Includes JST type PH 2.0 cable for quick line input connection
CLEARANCE $12.13
MSRP: $23.99
Save $11.86 (49%)
77 In Stock
We'll send you an email when T-Amp Tripath TA2024 2 x 15W Audio Digital Amplifier Board is back in stock or available for preorder.
Order in the next 9 hr 53 min to ship today. Details
This board is designed around the Tripath TA-2024 integrated circuit. The TA2024 is a 15W/channel continuous average two-channel Class-T Digital Audio Power Amplifier IC using Tripath's proprietary Digital Power Processing™ technology. Class-T amplifiers offer both the audio fidelity of a Class-AB amplifier and the power efficiency of a Class-D amplifier.
Perfect for projects, this board features over-current and over-temperature protection circuits. It can be built into powered speakers or used as a standalone amplifier. The board's small size is even ideal for inclusion in OEM products or store displays.
Specifications: • Output power: 9W x 2 @ 4 ohms (0.04% THD+N), 11W x 2 @ 4 ohms (0.1% THD+N), 6W x 2 @ 8 ohms (0.1% THD+N), 15W x 2 @ 4 ohms (10% THD+N), 10W x 2 @ 8 ohm (THD+N) • IHF-IM: 0.18% @ 1W, 4 ohms • Efficiency: 88% @ 10W, 8 ohms • Dynamic range: 102 dB • Recommended power: 12 VDC, 2A • Dimensions: Board: 3.54" x 2.09" (90 x 53 mm); Mounting holes (center to center): 2.88" x 1.81".
Part Number320-600
UPC848864051345
Weight0.1
Board Type2 Channel Stereo Amp
Power (RMS/Channel 8 ohms)0 - 25 Watts
