  • Switchcraft HPCP41F HPC Panel Mount 4-Pole Receptacle
SwitchcraftPart # 093-456
Model: HPCP41F
The HPCP41F panel mount 4-pole receptacle has a 0.100" flange depth and 0.250" Faston terminals. Compatible with Speakon®.
  • Flange depth 0.100"
  • Built-in gasket allows HPC panel mounts to meet IP 25 harsh environment ratings
  • 50A rating per UL 1977
  • 0.250" Faston terminals allow for easy assembly
  • Compatible with Speakon®
Your Price: $8.41
Save $4.64 (36%)
99 In Stock
We'll send you an email when Switchcraft HPCP41F HPC Panel Mount 4-Pole Receptacle is back in stock or available for preorder.
Order in the next 2 hr 18 min to ship today. Details
The HPC panel mounts have been updated with new silver-plated contact materials that boost the contact ratings to 50A per UL 1977. The HPCP41F panel mount 4-pole receptacle has a 0.100" flange depth and 0.250" Faston terminals. Compatible with Speakon®. The unique feature of the HPC series is the push to lock feature, similar to the connection of an XLR connector. The HPC cord plugs, when mated to HPC panel mounts, do not require a 1/4 turn to engage—simply push the connector in until it locks. To disengage, push forward on the latch lever and pull the connector out. This feature eliminates the need to remember to turn the connector to make contact. The connector will also mate to Neutrik cable connectors but still requires a 1/4 turn.
BrandSwitchcraft
ModelHPCP41F
Part Number093-456
UPC844632072055
Weight0.1
Circuit4-Pole
GenderMale
