  • Switchcraft 35HDNN 3.5mm Stereo Plug Nickel
CLEARANCE Switchcraft 35HDNN 3.5mm Stereo Plug Nickel
SwitchcraftPart # 093-156
Model: 35HDNN
The 35HDNN 3.5 mm stereo cable mount plug features a one-piece flat tip rod for easy solderability with a nickel shell. A heavy duty cable clamp provides better strain relief for larger cables.
  • Large solder terminal for easy solderability
  • Insert molded plug finger
  • Longer handle for improved gripping surface and easy plug withdrawal from jack
We'll send you an email when Switchcraft 35HDNN 3.5mm Stereo Plug Nickel is back in stock or available for preorder.
The 35HDNN 3.5 mm stereo cable mount plug features a one-piece flat tip rod for easy solderability. A heavy duty cable clamp provides better strain relief for larger cables. Tubular insulator included to prevent solder joints from contacting handle. Longer cable clamp allows for easier plug assembly. The knurl on the back of the handle provides ergonomic gripping surface to tighten the plug. Mfg. #35HDNN. It accepts up to 0.290" diameter cable.
BrandSwitchcraft
Model35HDNN
Part Number093-156
UPC844632071768
Weight0.1
ConductorsStereo TRS
GenderMale / Plug
Jacket ColorSilver
Mounting TypeCable Mount
