  • Switchcraft 236 1/4" Stereo 90 degree Plug Nickel
SwitchcraftPart # 093-132
Model: 236
Switchcraft's 1/4" right-angle stereo mount plugs are designed for OEMs and users of commercial phone plugs. Tip, rod, and handle are all nickel-plated copper alloy. Features include solder terminals with a shielded handle.
  • 3-piece assembly
  • Rugged all metal exterior construction
  • Large terminals accept up to 16 AWG wiring (cables up to 0.25" diameter)
  • Right-angle handle minimizes space required behind equipment
Your Price: $7.80
Save $9.49 (55%)
31 In Stock
We'll send you an email when Switchcraft 236 1/4" Stereo 90 degree Plug Nickel is back in stock or available for preorder.
Order in the next 0 hr 16 min to ship today. Details
Switchcraft's 1/4" right-angle stereo mount plugs are designed for OEMs and users of commercial phone plugs. Features include solder terminals with a shielded handle. The plugs offer large terminals for easy wiring, and only three pieces to assemble - handle, insulator, and finger/housing assembly - and feature rugged reliability for stable, long-term, trouble-free operation. At only a 1/2" wide, these plugs are ideal for crowded, multi-channel panels. Rugged cable clamp isolates pulling and twisting strains. Knurled handles allow for a positive grip during connect/disconnect. Mfg. #236. Specifications: • Housing/sleeve: Nickel plated • Tip terminal: Tin-plated copper alloy • Sleeve (clamp) terminal: Tin-plated steel • Insulation: Thermoplastic • Dielectric withstanding voltage: 500 VAC • Insulation resistance: 50,000 Mohms minimum (initial) • Operating temperature: -20°C to +65°C.
BrandSwitchcraft
Model236
Part Number093-132
UPC844632071720
Weight0.1
ConductorsStereo TRS
GenderMale / Plug
Mounting TypeCable Mount
