  • Speaker Surround Re-Foam Repair Kit For 6-1/2" Speaker
Parts ExpressPart # 260-915
Don't throw away expensive loudspeakers just because the foam surround has dry rotted, or has been punctured. With these new refoam kits from Parts Express, you can save BIG bucks by repairing the foam surround and avoid costly loudspeaker replacements.
Your Price: $28.49
MSRP: $34.99
Save $6.50 (19%)
Only 18 In Stock
Don't throw away expensive loudspeakers just because the foam surround has dry rotted, or has been punctured. With these new refoam kits from Parts Express, you can save BIG bucks by repairing the foam surround and avoid costly loudspeaker replacements. The kit includes one pair of foam surrounds, 1 oz. of adhesive (specially formulated for various speaker cone materials), five foam swabs for application of glue and complete repair instructions. A utility knife and isopropyl alcohol are recommended to remove old foam material, but are NOT included in this kit.
Specifications: • Foam outside diameter: 6" • Foam inside diameter: 4-1/4" • Foam outer edge width: 3/16" • Foam inner edge width: 1/4" • Roll width: 3/8" • Dustcap diameter: 2-1/2".
Note: This speaker surround repair kit is not designed for use with subwoofers.
Part Number260-915
UPC844632043529
Weight0.46
