  • ME-TM42123 Blue LED Temperature Display Dual External Sensors
Sure ElectronicsPart # 320-500
Model: ME-TM42123
This seven segment LED temperature meter features two thermal probes for measuring two environments at the same time.
  • Measure two environments at once in °C or °F with included probes
  • Auto-sensing brightness and auto temperature conversion
  • Perfect for the precise monitoring rack closets or fish tanks
  • Wide-range working voltage
  • Includes 8" power cable and temperature probes on 39" long cables
Your Price: $18.98
MSRP: $35.99
Save $17.01 (47%)
Quantity:Qty: 1-3 $18.98/ea
Quantity:Qty: 4-9 $17.97/ea
Quantity:Qty: 10+ $17.54/ea
Out of Stock
We'll send you an email when ME-TM42123 Blue LED Temperature Display Dual External Sensors is back in stock or available for preorder.
These temperature displays offer the ability of measuring two different environments at the same time in Celsius (°C) or Fahrenheit (°F), making it perfect for monitoring the temperature of your equipment closet, computer case, amplifier, fish tank or for comparing two devices under test.
Three 7-segment bright blue LEDs offer great visibility and a wide viewing angle. Additionally, this display features auto-brightness for reduced power consumption in darker settings and offers the ability to change the display from Celsius to Fahrenheit with a wave of a hand. The small display housing footprint opens up application possibilities and since it can run on 12 VDC (8.5 to 26 VDC working voltage), this display is right at home in your car or truck.
Included with this display are two waterproof NTC thermal probes on 39" long cables that offer durability and precision. Cables are UL and CE-certified for low voltage drop. 8" power cable included.
Specifications: • Power requirement: 8.5 to 26 VDC • Current consumption: 36 mA (@ 12 VDC) • Temperature range: -24° C (-11° F) to 125° C (257° F) • Display resolution: 0.1° (@ -9.9° C/F to 99.9° C/F), 1° (@ 100° F and above) • Accuracy: ±1.0° C • Dimensions: 3.11" W x 1.65" H x 0.98" D (79 x 42 x 25 mm).
BrandSure Electronics
ModelME-TM42123
Part Number320-500
UPC844632093159
Weight0.25
