  • ME-TM32123 Blue LED Temperature Display Internal & External Sensor
Sure ElectronicsPart # 320-502
Model: ME-TM32123
This three 7-segment bright blue LED temperature display features a built-in sensor and an external sensor. Great for comparing a remote environment against the display's environment.
  • Measure two environments at once in °C or °F with included probe or on-board sensor
  • Auto-sensing brightness and auto temperature conversion
  • Perfect for the precise monitoring of the temperature, indoors and outside
  • Wide-range working voltage
  • Includes 8" power cable and temperature probe on 119" long cable
  • Easy to read 0.56" LED display
Your Price: $17.98
MSRP: $34.99
Save $17.01 (49%)
Quantity:Qty: 1-3 $17.98/ea
Quantity:Qty: 4-9 $17.27/ea
Quantity:Qty: 10+ $16.87/ea
Out of Stock
We'll send you an email when ME-TM32123 Blue LED Temperature Display Internal & External Sensor is back in stock or available for preorder.
Temperature displays offer the ability of measuring two different environments (one local, one remote) at the same time in Celsius (°C) or Fahrenheit (°F), making it perfect for monitoring the temperature of your equipment closet, computer case, amplifier, fish tank, pool or for comparing your indoor temperature versus the temperature outdoors.
Three 7-segment bright blue LEDs offer great visibility and a wide viewing angle. Additionally, this display features auto-brightness for reduced power consumption in darker settings and offers the ability to change the display from Celsius to Fahrenheit with a wave of a hand. The small housing footprint opens up application possibilities and since it can run on 12 VDC (8.5 to 26 VDC working voltage), this display is right at home in your car or truck.
Included with this display is a waterproof NTC thermal probe on a 119" long cable. The cable is UL and CE-certified for low voltage drop. 8" power cable included.
Specifications: • Power requirement: 8.5 to 26 VDC • Current consumption: 36 mA (@ 12 VDC) • Temperature range: Internal sensor: 0° C (32° F) to 60°C (140°F), External probe: -24° C (-11° F) to 125°C (257°F) • Display resolution: 0.1° (@ -9.9° C/°F to 99.9° C/F), 1° (@ 100°F and above) • Accuracy: Internal sensor: ±2.0°C, External probe: ±1.0°C • Dimensions: 3.11" W x 1.65" H x 0.98" D (79 x 42 x 25 mm).
BrandSure Electronics
ModelME-TM32123
Part Number320-502
UPC844632093166
Weight0.25
