  • ME-TM11123 Red Digital Thermometer LED Temperature Display Internal Sensor
Sure ElectronicsPart # 320-524
Model: ME-TM11123
Quickly check the internal temperature of your equipment rack with this temperature display.
  • Measure a local environment in °C or °F with on-board sensor
  • Auto-sensing brightness and auto temperature conversion
  • Perfect for the precise temperature monitoring on a car or truck's dash
  • Wide-range working voltage
  • Easy to read 0.56" LED display
Your Price: $16.98
MSRP: $29.99
Save $13.01 (43%)
Quantity:Qty: 1-3 $16.98/ea
Quantity:Qty: 4-49 $16.12/ea
Quantity:Qty: 50+ $15.75/ea
We'll send you an email when ME-TM11123 Red Digital Thermometer LED Temperature Display Internal Sensor is back in stock or available for preorder.
Temperature displays offer the ability of measuring a local environment in either Celsius (°C) or Fahrenheit (°F), making it perfect for monitoring the temperature in your equipment closet.
Three 7-segment red LEDs offer great visibility and a wide viewing angle. Additionally, this display features auto-brightness for reduced power consumption in darker settings and offers the ability to change the display from Celsius to Fahrenheit with a wave of a hand. The small housing footprint opens up application possibilities and since it can run on 12 VDC (8.5 to 26 VDC working voltage), this display is right at home in your car or truck. 8" power cable included.
Specifications: • Power requirement: 8.5 to 26 VDC • Current consumption: 36 mA (@ 12 VDC) • Temperature range: 0°C (32°F) to 60°C (140°F) • Display resolution: 0.1° (@ -9.9°C/°F to 99.9°C/F), 1° (@ 100°F and above) • Accuracy: ± 2.0°C • Dimensions: 3.11" (79 mm) W x 1.65" (42 mm) H x 0.98" (25 mm) D.
BrandSure Electronics
ModelME-TM11123
Part Number320-524
UPC844632093272
Weight0.25
