The Wondom AA-BK31394 is the perfect amp board to power your next high power active speaker project. It uses the STA516BE chip to deliver a warm, but powerful sound that you can only get from a Class-T IC. Combine an active crossover with a single subwoofer or design a 4-way powered speaker with individual passive hi and low filters to create a powerful high quality sound. This amp board needs very little space, so if you want to design a high power small active monitor the AA-BK31394 board is your answer. Four Screw in standoffs included for easy mounting
This Wondom amp board includes the MB-BB41112 input interface and control breakout board for quick integration with passive mixing boards. The inputs include XLR and RCA jacks or bare wire, and it has a monitor output for verifying the inputs. The control functions include signal detection and power switch option.
• Input power: 36 to 60 VDC
• Output power (w/56 VDC power supply): 1,000W (2 ohms, THD 10%), 800W (2 ohms, THD 1%)
• Maximum current draw: 19A
• Frequency response: 20 - 20,000 Hz
• Minimum impedance: 2 ohms
• Size: 3.9" x 3.9" x 1.97"
