  • Stahl Tools SPB112 0.039" (1.0mm) Solder 60/40 Pocket Pack Tube 12g
CLEARANCE Stahl Tools SPB112 0.039" (1.0mm) Solder 60/40 Pocket Pack Tube 12g
Stahl ToolsPart # 374-614
Model: SPB112
These solder tubes fit perfect into tool boxes and soldering iron cases. The solder conveniently feeds through the top of the handy dispenser tube.
  • Convenient size with dispenser tube
  • Standard 0.039" (1 mm) diameter, 60/40 formula with 2% flux for PC board soldering
We'll send you an email when Stahl Tools SPB112 0.039" (1.0mm) Solder 60/40 Pocket Pack Tube 12g is back in stock or available for preorder.
The storage tube helps keep the 60% tin, 40% lead, and 2% flux from being exposed to contaminants and the 0.42 oz. (12 grams) size makes it perfect to carry in small tool boxes, cases, and tool belts. The 0.039" diameter works best for PC board soldering.
BrandStahl Tools
ModelSPB112
Part Number374-614
UPC848864049687
