Stahl Tools F10WC-5 Cree XML2(T6) 10W LED Flashlight with 18650 Li-Ion Battery and Charger 1100 LumensThe Stahl Tools F10WC-5 is the ultimate 5" tactical flashlight. 1,100 Lumen and five different modes surrounded by an aviation grade aluminum body make it the perfect flashlight for multiple applications and tough enough to use every day. The five different modes are full power, medium power, low power, strobe, and SOS. Toggle between the modes quickly by lightly pushing the button in so that it doesn't click. If you leave the flashlight off for more than 5 seconds it will return to full mode the next time you turn it on. The pull out zoom lens converts the extra wide beam into a narrow beam to focus on items in the distance. As you can see, this multifunction tactical flashlight is durable enough for security work, hunting, camping, or everyday use around the house.
This Stahl Tools flashlight kit comes with an 18650 rechargeable Li-Ion battery and charger that enables it to be used every day without going through a lot of batteries. The kit also comes with a three AAA battery holder for back-up in case your 18650 battery is not ready to use.
Note: Remove clear plastic wrap from battery before charging.
Specifications: • Dimensions: 125 mm L x 35 mm Dia. x 25 mm Dia. • Material: 6061-T6 aviation aluminum body • Waterproof rating: IP67 • Run time full power: 2 hours • Beam distance: Up to 300 meters • Weight 106 grams.
Includes:
• Flashlight
• 18650 Li-Ion battery
• Single bay 18650 AC battery charger
• Three AAA battery holder
