  • Splash Proof IP65 Snap-In Round 12 VDC Red Illuminated Rocker Switch
CLEARANCE Splash Proof IP65 Snap-In Round 12 VDC Red Illuminated Rocker Switch
Parts ExpressPart # 060-779
This SPST rocker switch's rubber boot enables it to work in moist environments. The red LED reveals the status of the switch.
  • Rubber boot helps seal out moisture
  • Stout 20A current rating
  • Red LED for status notification
  • Mounts easily in an 0.8" hole, or 0.78" hole with 0.02" D x 0.084" W x 0.4" L notch to avoid switch rotation
We'll send you an email when Splash Proof IP65 Snap-In Round 12 VDC Red Illuminated Rocker Switch is back in stock or available for preorder.
This rocker switch is great for outdoor automotive or off road vehicles exposed to moisture. The switch has a rubber boot surrounding the LED switch's lens to prevent moisture from getting to the switching mechanism. A red LED light provides on status for any 12 VDC project requiring less than 20A. To keep the switch from rotating after it is mounted there is a 0.02" D x 0.084" W x 0.4" L notch on the rocker switches body.
Specification: • Body dimensions: 0.73" Dia. at the bottom and 0.9" Dia. at the top x 0.66" H • Rocker dimensions: 0.30" H x 0.75" Dia. • Terminal size: 0.186" W x 0.30" H x 0.03" D.
Part Number060-779
UPC848864053219
CircuitSPST
Contact Rating @ Voltage20A 12 VDC
IlluminationIlluminated
