  • Speaker Cabinet Port Tube 1-13/16" ID x 2-7/16" L
BUYOUT Speaker Cabinet Port Tube 1-13/16" ID x 2-7/16" L
Factory BuyoutsPart # 269-2156
This high-quality port tube is perfect for tuning vented and bandpass enclosures. Ports are a press-fit style and can be trimmed to length if needed.
  • One piece polypropylene construction
  • Clean, professional finish for ported and bandpass enclosures
  • Easily trimmed to length for proper tuning
  • Also useful as trim for wire and cable pass through holes
BUYOUT $0.92
1041 In Stock
We'll send you an email when Speaker Cabinet Port Tube 1-13/16" ID x 2-7/16" L is back in stock or available for preorder.
Order in the next 1 hr 38 min to ship today. Details
This high-quality port tube is perfect for tuning small high-performance bookshelf or stand mount speakers. These ports are also popular for use as a sleeve in pass through holes for wire and cable in counters, cabinets, and walls. Ports are a press-fit style and can be trimmed to length if needed. Requires 1.95" opening.
Dimensions:
Overall port length (including flange): 61 mm (2.4")
Overall front diameter (across flange): 62.5 mm (2.45")
Inner diameter: 45.5 mm (1.79")
Effective port length: 61 mm (2.4")
Mounting hole diameter: 50 mm (1.95")
BrandFactory Buyouts
Part Number269-2156
UPC848864026480
