  • Digital A-weighted Sound Level SPL Meter DT-85B
CLEARANCE Digital A-weighted Sound Level SPL Meter DT-85B
Parts ExpressPart # 390-723
The DT-85B Mini digital sound level meter is 6.5" in length making it perfect for your pocket or tool box. This A-weighted SPL meter is great for measuring overall SPL and monitoring noise and sound levels in any environment.
  • Backlight feature for large LCD display allows easy viewing in low light
  • Hold button to freeze current measurement
  • Calibration adjustment screw for improving and maintaining accuracy
  • Auto power off saves battery life when not in use
  • Threaded insert for standard tripod mount
  • One touch max/min measurements to find your limits and peaks
  • Ergonomic design improves comfort when taking measurements
We'll send you an email when Digital A-weighted Sound Level SPL Meter DT-85B is back in stock or available for preorder.
The DT-856B Mini digital sound level meter measures from 30 dB to 130 dB and is only 6.5" in length. This A-weighted meter is great for measuring and monitoring noise and sound in any environment, including in the work place, auto sound environments, and home theater rooms. Calibration screw is accessible on the back of the meter to dial in the accuracy for more precise measurements. Features MIN/MAX peak measurement, current reading hold, back lit display, excessive SPL warning (back light blinks above 100 dB), and auto power-off function to ensure long battery life.
  • Measurement range: 30 - 130 dBA
  • Frequency range: 31.5 Hz to 8 kHz
  • Accuracy: ± 1.5 dB (when calibrated to 94 dB @ 1,000 Hz)
  • Power: 3 x AAA battery (not included)
Part Number390-723
UPC848864069050
Weight0.4
