  • Solen Bi-Amp Speaker Terminal Cup Gold Plated Brass Binding Post Banana Jack
SolenPart # 260-240
With two pairs of gold plated binding posts and bridging bars, this recessed terminal cup is a perfect choice for use in bi-amp speaker systems or dual voice coil subwoofers. The rigid ABS cup ensures that this terminal is not a weak point in rigid enclosure designs. In addition, an included foam gasket makes it easy to install while keeping an air tight seal.
  • Gold plated brass binding posts keep contact resistance low while preventing corrosion
  • Hex style knob makes it easy to securely tighten wires and spade connectors for a reliable connection
  • Dual parallel bridging bars for compatibility with bi-wire or single wire applications
  • Thick ABS cup will not be a lossy point in rigid enclosure designs
  • Included foam gasket for an airtight seal
See all items in Terminal Plates & Cups
Your Price: $23.98
MSRP: $23.99
Save $0.01 (0%)
Only 10 In Stock
We'll send you an email when Solen Bi-Amp Speaker Terminal Cup Gold Plated Brass Binding Post Banana Jack is back in stock or available for preorder.
Order in the next 0 hr 50 min to ship today. Details
With two pairs of gold plated binding posts and bridging bars, this recessed terminal cup is a perfect choice for use in bi-amp speaker systems or dual voice coil subwoofers. The rigid ABS cup ensures that this terminal is not a weak point in rigid enclosure designs. In addition, an included foam gasket makes it easy to install while keeping an air tight seal. Accepts up to 10 gauge wire and is compatible with dual banana plugs.
Dimensions:Overall size: 4-13/16" x 3-3/4", cutout: 3-7/8" x 3" • Connectors accept 0.205" female disconnect terminals • Includes gasket.
BrandSolen
Part Number260-240
UPC848864067940
Weight0.265
