  • Simply45 S45-C100 Pass Through Ratcheted Crimper for all S45 brand UTP & STP RJ45 Modular Plugs
CLEARANCE Simply45 S45-C100 Pass Through Ratcheted Crimper for all S45 brand UTP & STP RJ45 Modular Plugs
Simply45
Part #150-1000
Simply45
Part #150-1000
Model: S45-C100
Simply45 is the industry-leading brand for RJ45 modular plug innovation and performance solutions. Simply45's S45-C100 ratcheting RJ-45 crimp tool saves time and money by making the perfect RJ-45 termination every time. One tool cuts, strips, crimps, boots and trims the excess wire feeding through Simply45 color coded connectors.
  • Crimps SIMPLY45 RJ45 Plugs and SIMPLY45 Boots in one easy step
  • Multi-Functional - Cuts the wire, strips the jacket, trims and crimps
  • Delivers more torque during crimping cycle than other tools
  • Ratcheted for full cycle compression and uniform crimping
  • Precision manufactured to be durable and corrosion resistant
  • Wrapped reinforced steel die insures a smoother and more stable crimping cycle
  • Limited lifetime warranty from Simply45
Simply better quality and simply easier to use makes Simply45 the best RJ-45 crimper on the market. The ratcheting action sets it apart from all the rest. It helps you apply the right pressure every time during the crimping process of RJ-45 connectors, while the reinforced steel die insures a smoother and more stable crimp cycle. The diamond polished hardened steel blade trims at a slight angle relieving the pressure from trying trim straight down all at once. The S45-C100 crimps and trims the feed through design connectors which lets you make sure the wires are in the right location before you squeeze the handle. Look on the tools die to check wiring order for T-568A and T-568B. Nobody wants to waste RJ-45 connectors, so buy the Simply45 S45-C100 RJ-45 crimper and make the perfect connection every time. Replacement blades are available.
This all-in-one crimping tool also includes a wire cutter and stripper. This prevents you from having to carry multiple tools on hand or in a tool belt. Total tool dimensions with handle closed is 8" x 2.5" x 1".
BrandSimply45
ModelS45-C100
Part Number150-1000
UPC817777016857
Weight1.08
