  • Shadow Mounts CDAS30 Articulating Desktop Monitor Mount Arm 13"-30"
CLEARANCE Shadow Mounts CDAS30 Articulating Desktop Monitor Mount Arm 13"-30"
Shadow MountsPart # 182-415
Model: CDAS30
Read 8 Reviews or
Increase your productivity while decreasing eye and neck strain with Shadow Mounts' CDAS-30 monitor desk mount.
  • Reclaim valuable desk space—requires only 3.5" x 4" of mounting area
  • Reduces neck and eye strain by placing monitor at optimum viewing height and angle
  • Heavy-duty design will not sag over time
  • Includes cable management clips for a smart, clean appearance
  • Increases productivity and efficiency
  • Includes all the necessary installation hardware to fit multiple size screw holes found in monitors
  • Perfect for power users
CLEARANCE $6.75
MSRP: $39.99
Save $33.24 (83%)
47 In Stock
We'll send you an email when Shadow Mounts CDAS30 Articulating Desktop Monitor Mount Arm 13"-30" is back in stock or available for preorder.
Increase Productivity with Shadow Mounts' CDAS-30 Monitor Mount
Shadow Mounts' desktop monitor mounts are designed for computer monitors up to 30". Each mount is constructed of cold rolled steel for superior stability, even when fully extended it will not flex or sag. Copper joint offers smooth up and down tilt adjustments for maximum visibility no matter your seating position.
An ultra heavy-duty C-clamp, with integrated wide lock system and three mounting depths permanently affixes the mount to your desktop (from 0.39" to 3.5" thick) in no time flat. The CDAS-30 also includes through hole desk mount option. Height adjustments are quick and easy, and the monitor installs in either portrait or landscape positions effortlessly—rotating 360°—to fit your application perfectly.
Shadow Mount CDAS-30 increases productivity while decreasing eye and neck strain with an arm joint that offers up to 180° of swivel and ± 25° tilt viewing adjustment. The arm extends up to 15" freeing up crucial desk space. The CDAS-30 comes with cable management clamps to provide a neat, clean appearance and includes all the necessary installation hardware to fit multiple size screw holes found in monitors. The large round cable management clip also holds all the needed Allen wrenches for convenience.
Specifications: • Mount arm length: Adjustable up to 15" L • Mount height: Adjustable up to 15.7" H • Attaches to desk tops from 0.39" to 3.5" thick • Tilt adjustment: ± 25° • Swivel adjustment: 180° • Rotate adjustment: 360° • Supports one monitor weighing up to 17.6 lbs. • Compatible with 75 x 75 mm and 100 x 100 mm VESA patterns (for use with larger monitors, please see the Related Items section for VESA adapters).
Note: Applicable television size ranges are based on VESA standards and will fit the listed screen sizes. To ensure that this specific TV mount is not exposed behind your TV, identify the length and width of your specific TV and be sure that the mounting bracket, plate, and or articulating arm does not extend beyond your television’s measurements.
BrandShadow Mounts
ModelCDAS30
Part Number182-415
UPC848864072005
Weight6.45
Mount StyleDesk / Tabletop
Mount TypeSwivel / Tilt
TV CapacityUp to 19"-20" to 29"
