  • Self-Fusing Silicone Rubber Tape 1" x 10 ft. Roll Black
Parts ExpressPart # 350-100
Self fusing silicone tape is the most versatile and easy-to-use emergency repair product.
  • Self-fusing—creates a permanent air-tight, water-tight seal in seconds
  • Never gets gummy or sticky like electrical or duct tape — no messy cleanup
  • Resists fuels, oils, acids, solvents, salt water, road salt, and UV rays
  • Extremely versatile with an unbelievably long shelf life
  • Insulates 8,000 volts per layer and withstands temperatures from -65° F to 500° F
  • Meets or exceeds U. S. military spec. AA-59163 and UL 510
  • Made in the USA
Your Price: $9.38
Save $1.61 (15%)
We'll send you an email when Self-Fusing Silicone Rubber Tape 1" x 10 ft. Roll Black is back in stock or available for preorder.
Order in the next 0 hr 34 min to ship today. Details
Self-fusing tape chemically bonds to itself creating a water-tight seal to whatever it's wrapped around. It's not like electrical tape that becomes gooey in hot temperatures. This self-fusing tape withstands temperatures up 500° F which makes it great for automotive repairs around the engine compartment, under the dash, and in the trunk. Repair wiring insulation, radiator hoses, and vacuum tubes just to name a few.
It has an infinite number of uses around the house too. This tape fixes leaking pipes and hoses to rewrapping worn-out rubber handles on sporting equipment. It seals out moisture for outdoor cable and speaker connections. Just stretch and wrap the self-fusing tape around the needed area to fix or protect. Then stretch and wrap again over each side of the first wrap. The tape will bond to the area being wrapped and to itself creating an air-tight/water-tight seal.
Specifications: • UL listed - meets UL standard 510 • Meets or exceeds U.S. MIL Spec AA-59163 • Operating temperature: -65° F to 500° F • Dielectric strength: Tested to ASTM D-149 (overlapping increases dielectric strength) • Tensile strength: Tested to ASTM D-412 700 PSI • Tear Resistance: 85 PSI • Hardness: 50 shore durometer • Resists: UV, Oil & Chemicals • Insulates: 8,000 Volts per layer • Roll Size: 1" W x 10 ft. L x 0.02" thick • Color: Black.
Part Number350-100
UPC848864053141
Weight0.1
