  • Sanus SSMK1-X1 Universal Steel Stud Mounting Kit for Tilting and Fixed TV Mounts
CLEARANCE Sanus SSMK1-X1 Universal Steel Stud Mounting Kit for Tilting and Fixed TV Mounts
SanusPart # 185-3643
Model: SSMK1-X1
The Sanus SSMK1-X1 steel stud hardware kit is a must if you are mounting your TV into steel studs. It provides everything you need for your tilt or fixed position wall mount to be safely mounted into steel studs.
  • UL Listed hardware can support up to 175 lbs. in steel studs
  • Includes all the hardware you need to mount into steel studs
  • Perfect for mounting tilting or fixed position mounts
We'll send you an email when Sanus SSMK1-X1 Universal Steel Stud Mounting Kit for Tilting and Fixed TV Mounts is back in stock or available for preorder.
The Sanus steel stud hardware kit is a must if you are mounting your TV into steel studs. It provides everything you need for your tilt or fixed position wall mount to be safely mounted into steel studs. The UL Listed hardware can support up to 175 lbs. and is perfect for mounting tilting or fixed position mounts. Note - we do not recommend using a full-motion mount in steel studs. They can twist and can become unsafe.
BrandSanus
ModelSSMK1-X1
Part Number185-3643
UPC793795363435
Weight0.4
