  • Sanus CFR2127-B1 27U Home Theater Component Rack System with Blanking Panels and Vented Shelves
CLEARANCE Sanus CFR2127-B1 27U Home Theater Component Rack System with Blanking Panels and Vented Shelves
Sanus
Part #240-8603
Sanus
Part #240-8603
Model: CFR2127-B1
The Sanus Component Series CFR2127 rack system provides 27 rack spaces of easily customizable configurations. Quick-release back and side panels allow complete and total access to components and wiring providing easy installation. A built-in cooling system ensures your AV gear stays cool during heavy use.
  • 27U customizable rack system with a built-in cooling system to keep your equipment cool and easily accessible
  • Heavy-gauge steel construction with lockable tempered glass doors and removeable panels
  • Preassembled with hardware included for easy installation
CLEARANCE $1,249.99
Order in the next 2 hr 7 min to ship today. Details
1In Stock
Item available via truck freight in the United States only.
Additional charges will apply at checkout.
The Sanus Component Series CFR2127 rack system can support up to 750 lbs of AV gear. It comes pre-assembled with blanking panels and vented shelves, which include back stops to ensure AV equipment does not move during use. Quick-release back and side panels allow complete and total access to components and wiring. The rack has two 3U cut-out openings on both top and bottom of the rack as well as a removable 3U panel that can be located above or below the rear rack door for added venting or active cooling flexibility. Swivel casters and adjustable feet allow mobility and stable positioning, and cooling vents on the top and bottom of the rack ensure all equipment stays at the ideal temperature. The CFR2127 comes with additional accessories to gang racks together and to make the side panels lockable.
Weight capacity: 750 lbs.
Useable depth: 21.6"
Useable width: 19.4"
Rack spaces: 27
1U shelf dimensions: 17.4" W x 18.2" D x 1.75" H
1U shelf weight capacity: 30 lbs.
1U shelf qty: 2
1U blanking panel qty: 2
2U shelf width: 17.4" W x 18.2" D x 3.5" H
2U shelf weight capacity: 50 lbs.
2U shelf qty: 4
2U blanking panel qty: 4
Rack weight: 129 lbs.
Rack dimensions (with casters): 23.6" W x 23.6" D x 55.0" H
BrandSanus
ModelCFR2127-B1
Part Number240-8603
UPC793795524010
Weight130
Rack Spaces27
