  • SPST NO Momentary 19mm Stainless Steel Waterproof Raised Push Button Tamper Proof Switch 6A 125V
Parts ExpressPart # 060-653
Use this heavy duty, Stainless steel, anti-vandal raised push button momentary switch for outdoor and other extreme condition applications.
  • Popular for use in kiosk applications, ticket dispensers, and industrial-type applications
  • Stainless steel body and IP65 rating for extreme conditions
  • Silver contacts for long-lasting connection
  • RoHS certified
  • Includes rubber washer for IP65 rating
  • Screw terminals for quick connection
  • Easily mounts in a 3/4" hole with included shaft nut
Your Price: $5.49
Save $2.50 (31%)
We'll send you an email when SPST NO Momentary 19mm Stainless Steel Waterproof Raised Push Button Tamper Proof Switch 6A 125V is back in stock or available for preorder.
Estimated back in stock 9/18/2026
This anti-vandal push button switch is popular for use in kiosk applications, ticket dispensers and industrial-type applications. The stainless steel body and button stay looking great even with heavy duty use. The switch has an IP65 waterproof rating for extreme conditions indoors or outdoors when used with included rubber washer.
Specifications: Current rating: 3A 250 VAC/6A 125 VAC • Switch total size without screws: 1.1" L x 0.86" Dia. • Shaft size without button: 0.748" Dia. x 0.62" L • Button size: 0.05" H x 0.59" Dia.
Part Number060-653
UPC848864058993
CircuitN.O.
Contact Rating @ Voltage6A 125 VAC
IlluminationNon-Illuminated
