CLEARANCE SPST NO Momentary 19mm Stainless Steel Tamper/Waterproof Raised Push Button Switch with Blue Ring
- Popular for use in kiosk applications, ticket dispensers, and industrial-type applications
- Stainless steel body and IP67 rating for extreme conditions
- Built-in 3V blue LED with power ring illumination for low lit areas and connection identification
- Easily mounts in a 3/4" hole with included shaft nut
- 0.110" crimp/solder terminals for easy installation
- RoHS certified
- + and - symbols on the switch body for polarity identification for the built-in LED
We'll send you an email when SPST NO Momentary 19mm Stainless Steel Tamper/Waterproof Raised Push Button Switch with Blue Ring is back in stock or available for preorder.
