  • SPST NO Momentary 16mm Red Push Button Switch 5-Pack 6A 125V
CLEARANCE SPST NO Momentary 16mm Red Push Button Switch 5-Pack 6A 125V
Parts ExpressPart # 060-1005
Heavy duty NO push button momentary switches. They handle up to 6A of current at 125 VAC.
  • Economical 5-Pack
  • Easily mounts in a 5/8" hole
CLEARANCE $1.78
MSRP: $5.99
Save $4.21 (70%)
599 In Stock
We'll send you an email when SPST NO Momentary 16mm Red Push Button Switch 5-Pack 6A 125V is back in stock or available for preorder.
Heavy duty 16mm NO push button momentary switches. The economical 5-pack is perfect for projects that require multiple pushbuttons in a switch panel.
• Body dimensions: 0.75" Dia. x 0.77" at its largest points • Terminal size: 0.110" W x 0.21" L • Panel mounting thickness: Up to 0.3" • Hole cutout: 0.625" • Current rating: 6A @ 125 VAC, 3A @ 250 VAC.
Part Number060-1005
UPC848864062839
Weight0.06
