  • SPST Light Duty Toggle Switch Pre Wired
Parts ExpressPart # 060-543
This switch's preinstalled wires make it easy to add to any project, or replace an existing switch.
  • Prewired for quick installation
  • Mounts in a common 1/2" hole
  • Includes on/off identification plate
Your Price: $1.99
MSRP: $2.99
Save $1.00 (33%)
77 In Stock
We'll send you an email when SPST Light Duty Toggle Switch Pre Wired is back in stock or available for preorder.
Order in the next 0 hr 58 min to ship today. Details
Easily wire this SPST toggle switch directly to a project board, light, or small motor without any extra wires. This switch has preinstalled wires that solder directly to a PC board, small motor, or light that draws less than 6A @125 VAC. Quickly replace a bad switch in an appliance by splicing the existing wires to the preinstalled wires, on the new switch, with wire nuts or butt connectors. The new switch slides right into a standard 1/2" hole and the on/off plate makes it easy to identify the status of the switch.
Specifications: • Current rating: 6A @125 VAC or 3A @250 VAC • Body dimensions: 1.02" L x 0.55" W x 0.56" H • Shaft size: 0.35" H x 0.47" Dia. • Wire length: 2 x 5".
Part Number060-543
UPC848864044149
CircuitSPST
Contact Rating @ Voltage6A 125 VAC
IlluminationNon-Illuminated
