  • SPST 12mm Stainless Steel Waterproof Raised Push Button Latching Tamper Proof Switch 3V Red Ring 2A 36 VDC
Parts ExpressPart # 060-655
Use this heavy duty, Stainless steel, anti-vandal push button latching (push on/push off) switch for outdoor and other extreme condition applications. It has a built-in red light ring for 3 VDC applications.
  • Popular for use in kiosk applications, ticket dispensers, automotive, and industrial-type applications
  • Stainless steel body and IP65 rating for extreme conditions
  • Built-in 3 VDC red ring illumination for low lit areas and connection identification
  • RoHS certified
  • Includes rubber washer necessary to achieve IP65 rating
  • Easily mounts in 1/2" hole with included shaft nut
  • Tamper proof to prevent vandalizm
Your Price: $7.39
MSRP: $9.99
Save $2.60 (26%)
58 In Stock
We'll send you an email when SPST 12mm Stainless Steel Waterproof Raised Push Button Latching Tamper Proof Switch 3V Red Ring 2A 36 VDC is back in stock or available for preorder.
Order in the next 15 hr 24 min to ship today. Details
This anti-vandal push button switch is popular for use in kiosk applications, ticket dispensers, automotive, and industrial-type applications. The stainless steel body and push on/push off button stay looking great even with heavy duty use. The switch has an IP65 waterproof rating for extreme conditions indoors or outdoors when used with included rubber washer. This switch has a built-in 3 VDC red light for locating in low lit areas and connection identification.
Specifications: • Light rating: 3 VDC • Switch rating: 36V 2A • Terminal rating: 6A 125 VAC • Switch total size without terminals: 1.13" L x 0.55" Dia. • Metal shaft size without button: 0.47" Dia. x 0.74" L • Button size: 0.3" Dia. x 0.06 H • Terminal size: 0.08" W x 0.16" L x 0.025" D
Part Number060-655
UPC848864059006
Weight0.02
CircuitSPST
Contact Rating @ Voltage6A 125 VAC
IlluminationIlluminated
