  • Spring Loaded 4-1/2" Round Terminal Cup
BUYOUT Spring Loaded 4-1/2" Round Terminal Cup
Factory BuyoutsPart # 269-2194
This 4-1/2" round terminal cup has spring loaded terminals for quick and easy wire connection. Thanks to the 4 mounting holes in the flange this terminal is easy to install into a 3-1/2" hole.
  • 4-1/2" terminal cup mounts in a 3-1/2" hole
  • Includes a 1.4A auto reset circuit breaker
  • High quality spring loaded terminals provides quick and easy wire connection
  • Wires terminated with 0.205" female disconnect terminals
BUYOUT $0.98
Only 88 In Stock
We'll send you an email when Spring Loaded 4-1/2" Round Terminal Cup is back in stock or available for preorder.
Order in the next 12 hr 14 min to ship today. Details
The rear of the cup includes a 1.75A (125 watt) auto reset circuit breaker, and three sets of speaker leads terminated with 0.205" female quick disconnects for easy connection to drivers. One set of leads includes a 4.7 µF 100 V capacitor creating a 6 dB per octave high pass at 4,200 Hz to an 8 ohm load. Another set of leads includes a 5 watt 20 ohm resistor which is ideal for protecting a piezo super tweeter. The third set is a direct connection from the circuit breaker to the driver. All of which can easily be removed.
Dimensions : Outside diameter: 4-1/2", Cutout: 3-1/2"
Special purchase -- limited quantities available!
BrandFactory Buyouts
Part Number269-2194
UPC848864026626
Weight0.15
ConfigurationIncludes Connector Dish
Crossover TypeHigh Pass
