  • Rolls RA170 Rack Mount 70V Power Amplifier 70 Watt 1U
RollsPart # 245-1128
Model: RA170
The RA170 power amplifier was designed by Rolls specifically for the installation contractor. The RA170 is a single rack space unit with your choice of RCA or 1/4" unbalanced inputs.
  • 70 watts of clean 70V power
  • Simple spring-loaded output terminals
  • Single rack space
  • Durable construction for years of service
Your Price: $309.00
Save $90.00 (23%)
We'll send you an email when Rolls RA170 Rack Mount 70V Power Amplifier 70 Watt 1U is back in stock or available for preorder.
The RA170's 70 volt speaker outputs are provided via spring-loaded terminals - no transformer is required for speaker connection. The clean and straightforward front panel includes a power indicator LED, a volume control, and a clip LED which indicates an overload condition. The output circuitry is protected from momentary shorting and excessive load by a specially designed protective circuit. AC power adapter included. Made in the USA.
For more than two decades, those in the know have turned to Rolls for the highest quality, reliability, and value. Rolls is an innovative company specializing in domestically manufactured signal interface accessories, mixers, amplifiers, and processors for the audio professional.
Specfications: • Frequency response: 70 - 20,000 Hz • Power output: 70W maximum • Signal-to-noise ratio: 114 dB (@ 70W) • Dimensions: 19" x 1.75" x 5" • Weight: 5.5 lbs.
BrandRolls
ModelRA170
Part Number245-1128
UPC675889017007
Weight7.8
Power Output (RMS @ 70V)51W to 100W
Weight Range< 10 lbs.
