  • Rolls MP128 RFX Midibuddy MIDI Pedal Board
CLEARANCE Rolls MP128 RFX Midibuddy MIDI Pedal Board
RollsPart # 245-1218
Model: MP128
If you need a simple yet effective MIDI pedal foot controller, look no further than the MP128 from Rolls. You can send commands and program changes to any of 16 MIDI channels, as well as start/stop, and the MP128 will even operate on MIDI phantom power if your device supports it.
  • Easy to use MIDI controller
  • MIDI in, out and thru
  • Bright, clear LED display
  • Great for keyboards, effects processors, and other standard MIDI devices
We'll send you an email when Rolls MP128 RFX Midibuddy MIDI Pedal Board is back in stock or available for preorder.
Musicians and technical professionals in the industry need tools that do the job consistently, show after show, without requiring an advanced degree in applied mathematics or electrical engineering. Rolls understand this, so the MP128 from Rolls follows the same philosophy as any Rolls product. It works like a charm, and is super simple to setup and integrate into your rig.
A bank of DIP switches is used to select the MIDI channel the MP128 will use to send commands. Then, you just plug it and go! Ten footswitch pads are numbered 0 through 9 for selecting bank or program changes, and two additional pads are present to skip up or down in increments of ten for quick and easy control. It's really just that easy.
For more than two decades, those in the know have turned to Rolls for the highest quality, reliability, and value. Rolls is an innovative company specializing in domestically manufactured signal interface accessories, mixers, amplifiers, and processors for the audio professional.
BrandRolls
ModelMP128
Part Number245-1218
UPC675889012804
Weight4.4
