  • Rolls MO2020 Test Oscillator Variable Frequency Sine/Square Wave Generator
RollsPart # 245-1068
Model: MO2020
With sine and square wave capability, variable frequency, and being near pocket-sized, the MO2020 will quickly earn a spot in your toolbox -- on top, where you can reach it quickly. It's that good.
  • Frequency range from 20 Hz to 24 kHz
  • 1/4" TS outputs
  • -10 dB pad for referencing
  • Power loop-thru for passing power to additional devices
Your Price: $119.00
Save $40.00 (25%)
We'll send you an email when Rolls MO2020 Test Oscillator Variable Frequency Sine/Square Wave Generator is back in stock or available for preorder.
The MO2020 by Rolls provides a sine and square wave output on two 1/4" jacks. The frequency range is variable from 20 Hz to 24 kHz, it accepts a 1.2 to 5 volt DC input on a 1/4" jack for external frequency control, and a 10 dB output pad is included to provide a -10 dB reference signal. AC power adapter included. Made in the USA.
Specifications: • Output Level: +11 dB Sine, +14 dB Square • Output impedance: 100 ohms • THD (Sine): <1% • Dimensions: 4.25" x 3.75" x 1.75" • Power input: 12-16 VDC 50 mA.
For more than two decades, those in the know have turned to Rolls for the highest quality, reliability, and value. Rolls is an innovative company specializing in domestically manufactured signal interface accessories, mixers, amplifiers, and processors for the audio professional.
BrandRolls
ModelMO2020
Part Number245-1068
UPC675889202007
Weight1.5
