  • Rolls DB24 Stereo Direct Interface Balanced/Unbalanced Converter
CLEARANCE Rolls DB24 Stereo Direct Interface Balanced/Unbalanced Converter
RollsPart # 245-1016
Model: DB24
The DB24 is a two channel isolation device designed to connect high impedance devices to low impedance. The unit is completely passive, and utilizes Rolls' proprietary audio transformers for superior sound.
  • Stereo RCA, 1/8" (3.5mm), and dual 1/4 inputs
  • Balanced XLR outputs
  • Ground lift for each channel
  • Individual variable attenuators
  • Small form factor
CLEARANCE $99.00
MSRP: $139.00
Save $40.00 (29%)
3 In Stock
We'll send you an email when Rolls DB24 Stereo Direct Interface Balanced/Unbalanced Converter is back in stock or available for preorder.
A heavy duty steel chassis was chosen for the DB24 to provide maximum reliability when used in demanding live sound reinforcement applications. A variety of inputs are provided including stereo and mono 1/4", stereo RCA, and stereo 1/8" (3.5mm). The DB24 is an ideal impedance matching device for connecting any unbalanced stereo signal to a balanced system. Consumer audio equipment such as CD players, DVD players, MP3 players, etc., may be easily connected to a professional audio system. Made in the USA.
Specifications: • Dimensions: 3.42" x 3.325" x 1.45" • Weight: 1.5 lbs.
For more than two decades, those in the know have turned to Rolls for the highest quality, reliability, and value. Rolls is an innovative company specializing in domestically manufactured signal interface accessories, mixers, amplifiers, and processors for the audio professional.
BrandRolls
ModelDB24
Part Number245-1016
UPC675889002409
Weight1.1
Mixer TypeAnalog
