CLEARANCE Rolls DB227 Podcast Pro Mic/Source Passive Mixer
Rolls
Part #245-1200
Rolls
Part #245-1200
Model: DB227
The DB227 from Rolls is perfect for podcasting. It allows you to mix your mic signal with either an RCA or 3.5 mm line level input (like background music) and sends the mix out via a balanced XLR output.
- Mix your mic with background music or other interesting sounds
- Source input can be RCA or 3.5 mm stereo
- Source level can be adjusted for the perfect mix
- Ground lift switch eliminates pesky humming
We'll send you an email when Rolls DB227 Podcast Pro Mic/Source Passive Mixer is back in stock or available for preorder.
