  • Rolls DB14b AV Presenter Stereo Patch Direct Box
CLEARANCE Rolls DB14b AV Presenter Stereo Patch Direct Box
RollsPart # 245-1012
Model: DB14b
The DB14b is a special purpose direct box for applications where a stereo source signal can be separated, and individual volume controls used for each track.
  • Splits stereo RCA and stereo 1/8" (3.5mm) signals
  • Individual Right and Left level controls
  • Transformer balanced XLR mono output
  • Hum eliminating ground lift switch
  • Very small form factor
We'll send you an email when Rolls DB14b AV Presenter Stereo Patch Direct Box is back in stock or available for preorder.
The DB14b by Rolls provides a summed XLR output for uses such as an AV presentation from a laptop computer, or a rehearsing choir to a music track. Hum elimination is also included with the ground lift switch. It has stereo RCA and 1/8" (3.5 mm) inputs, L+R volume controls, RCA and XLR outputs, and uses no power. Made in the USA.
Specifications: • Frequency response: 50 - 16,000 Hz (Low Z) • Maximum input level: +20 dB • Maximum output level: +20 dB (RCA); 0 dB (XLR) • Dimensions: 2" x 3.5" x 1.25" • Weight: 1 lb.
For more than two decades, those in the know have turned to Rolls for the highest quality, reliability, and value. Rolls is an innovative company specializing in domestically manufactured signal interface accessories, mixers, amplifiers, and processors for the audio professional.
BrandRolls
ModelDB14b
Part Number245-1012
UPC675889001419
Weight0.5
Active / PassivePassive
Rack MountableNo
