  • Replacement Anti-Skating Weight for Dayton Audio TT-1BT Turntable
NEW Replacement Anti-Skating Weight for Dayton Audio TT-1BT Turntable
Dayton AudioPart # 999-3622
Model: D3622
Restore your turntable’s precision with the Replacement Anti-Skating Weight for the Dayton Audio TT-1BT. Designed specifically for this model, the anti-skating weight plays a vital role in maintaining even stylus pressure across the record surface—preserving both your vinyl and cartridge.
  • Factory-designed for the Dayton Audio TT-1BT — ensures perfect compatibility and correct tonearm tension
  • Preserves stylus alignment and tracking for balanced audio playback across the entire record
  • Ideal replacement if the original anti-skating weight is lost, damaged, or worn out
  • Precision-calibrated mass provides reliable anti-skating compensation without guesswork
  • Genuine Dayton Audio part for seamless restoration of factory tonearm performance
We'll send you an email when Replacement Anti-Skating Weight for Dayton Audio TT-1BT Turntable is back in stock or available for preorder.
ModelD3622
Part Number999-3622
UPC848791011320
Weight0.01
