  • Replacement 20.8mm Filters for Stahl Tools Station DSDS Desoldering Gun Base Attachment Tube 10-Pack
Parts ExpressPart # 374-407
These replacement filter pads keep the suction capacity at peak performance in your Stahl Tools DSDS soldering station's desoldering gun.
  • Keeps suction at maximum capacity when changed regularly
  • Economic 10-pack
  • Exact size as current filters for compatibility
Your Price: $2.59
MSRP: $3.99
Save $1.40 (35%)
Out of Stock
We'll send you an email when Replacement 20.8mm Filters for Stahl Tools Station DSDS Desoldering Gun Base Attachment Tube 10-Pack is back in stock or available for preorder.
Replace the filter inside your DSDS desoldering gun's suction tube to keep suction at maximum capacity. Solder splatter clings to the cotton filter preventing damage to the motor inside the DSDS soldering station. Eventually the filter will attract so much solder that it affects the suction power of the desoldering gun. Carefully replace the filter inside the cap that attaches the soldering tube to the soldering base as needed with one of these new filters to return your desoldering gun to maximum suction power. These exact replacements measure 20.8 mm in diameter.
Part Number374-407
UPC848864059747
Unit of MeasurePackages
