  • Regulated Variable DC Power Supply 1.5-15V 0-2A
CLEARANCE Regulated Variable DC Power Supply 1.5-15V 0-2A
HYELECPart # 120-900
Model: PS-28A
This HYELEC PS-28A regulated power supply is continuously adjustable between 1.5V~15V DC and has a digital red LED display that shows voltage and current draw up to 2A.
  • Easy to read red digital LED display shows voltage and current draw
  • Adjustable regulated voltage for accuracy
  • 90V~253V AC 50 Hz/60 Hz voltage for international use
  • Over temperature protection built-in
  • CE and RoHS certified
We'll send you an email when Regulated Variable DC Power Supply 1.5-15V 0-2A is back in stock or available for preorder.
This compact sized regulated power supply is ideal for all devices drawing up to 2 amperes. It's fully regulated to assure a constant, accurate voltage output. Rotate the selector knob to choose voltages from 1.5V~15V DC. The small 4-5/8" W x 5-1/8" D x 2-1/4" H size enable it to be carried from home to job site for powering portable TV sets, video games, tape recorders, radios, scanners, boom boxes, etc. The red and black binding posts enable easy connection to many appliances.
Specifications: • Input voltage: 90V~253V AC, 50 Hz/60 Hz ±2 Hz • Voltage output: 1.5~15 VDC • Maximum current: 2A • Working environment: 32°~104° F (0°~40° C) with relative humidity <90%.
BrandHYELEC
ModelPS-28A
Part Number120-900
UPC848864059204
Weight0.85
DC Output VoltageVariable
Input Voltage100~240 VAC
