  • Rean NYS225L 1/4" Mono Plug Nickel For Speaker Cable
ReanPart # 092-149
Model: NYS225L
Commercial wide-body 1/4" mono phone plug designed specifically for use with heavy-gauge speaker wire. Features machined turned brass construction, a larger-than-typical crimp cable clamp, a larger cable outlet, rubber bushing, and oversized solder tabs that accept up to 12 gauge wire.
  • 1/4" mono (TS) phono plug
  • Make your own cables to the perfect length
  • Repair your own cables and save money
  • Rugged construction
  • Nickel finish
Your Price: $3.18
MSRP: $3.66
Save $0.48 (13%)
51 In Stock
We'll send you an email when Rean NYS225L 1/4" Mono Plug Nickel For Speaker Cable is back in stock or available for preorder.
Specifications: • Connector type: 1/4" mono plug (2 pole) • Handle: Nickel • Contacts: Nickel • 57.5 mm long handle; 89.0 mm overall length; 19.0 mm handle diameter • Accepts cable O.D. up to 9 mm • Mfg. #NYS 225L.
REAN — a brand of Neutrik AG
BrandRean
ModelNYS225L
Part Number092-149
UPC844632004711
Weight0.1
ConductorsMono TS
GenderMale / Plug
Mounting TypeCable Mount
