  • Rean NYS225 1/4" Mono Plug Nickel For Speaker Cable
ReanPart # 092-147
Model: NYS225
Commercial wide-body 1/4" mono phone plug designed specifically for use with heavy-gauge speaker wire. Features machined turned brass construction, a larger-than-typical crimp cable clamp, a larger cable outlet, rubber bushing, and oversized solder tabs that accept up to 12 gauge wire.
  • 1/4" mono (TS) phono plug
  • Make your own cables to the perfect length
  • Repair your own cables and save money
  • Rugged construction
  • Nickel finish
Your Price: $2.57
MSRP: $2.95
Save $0.38 (13%)
144 In Stock
We'll send you an email when Rean NYS225 1/4" Mono Plug Nickel For Speaker Cable is back in stock or available for preorder.
Order in the next 2 hr 33 min to ship today. Details
Specifications: • Connector type: 1/4" mono plug (2 pole) • Handle: Nickel • Contacts: Nickel • 57.5 mm long handle; 89.0 mm overall length; 19.0 mm handle diameter • Accepts cable O.D. up to 8 mm • Mfg. #NYS 225.
REAN — a brand of Neutrik AG
BrandRean
ModelNYS225
Part Number092-147
UPC844632004698
Weight0.1
ConductorsMono TS
GenderMale / Plug
Mounting TypeCable Mount
