  • Radian 745NEOPB 1.4" Aluminum Compression Driver 8 Ohm
The 745NEO, with a 3" diaphragm, represents the refinement of Radian's design efforts in 1.4" exit-format compression driver technology, and includes two bolt circle patterns— a standard 4" and a second one of 3.5" shifted by 45, for attachment to horns. The compact design is ideal for touring line arrays and high performance sound where light weight and very high SPL is needed. Heat stabilized polymer surround ensures that the 745NEO has low distortion and high SPL.
Superior sound quality, unparalleled power handling, extended high frequency response, and high reliability make Radian compression drivers the preferred choice of loudspeaker systems manufacturers, consultants, contractors, designers, and engineers around the world.
Specifications: • Power handling: 110 watts RMS/220 watts program power • VCdia: 3" • Impedance: 8 ohms • Frequency response: 500-20,000 Hz • SPL: 111 dB 1W/1m • Dimensions: 4.67" diameter x 2.17" depth.
