  • RESTOCKED Wireless 5 GHz HDMI Extender 1080p 100m/328 ft.
CLEARANCE RESTOCKED Wireless 5 GHz HDMI Extender 1080p 100m/328 ft.
Parts ExpressPart # 88-184-452
Refurbished/Restocked products may be factory authorized B stock or C stock that have been returned by customers or retailers for a variety of reasons and have been reviewed, repaired, or repackaged by the manufacturer or our in house repair department. They may have slight scratches, dents, signs of use, or other forms of cosmetic damage that do not affect usability or performance. Packaging may be non-original. Some items may be missing non-essential parts.
All Open Box and Refurbished/Restocked products are 100% covered by the Parts Express 60 Day No-Hassle Returns Policy. Order risk free and take up to 60 days to check it out. If any Open Box item does not meet your standards simply return it within 60 days for a full refund.
View This Item New
Extend your HDMI HD signal wirelessly up to 328 ft. with this wireless transmit/receiver set. The set also has a built-in IR extender for remotely controlling the source at the receiver's location.
  • Simple plug and play, no software needed
  • Extends HDMI signal up to 328 ft. for convenience
  • Compliant with HDCP 1.3
CLEARANCE $191.00
MSRP: $229.98
Save $38.98 (17%)
2 In Stock
We'll send you an email when RESTOCKED Wireless 5 GHz HDMI Extender 1080p 100m/328 ft. is back in stock or available for preorder.
Order in the next 5 hr 23 min to ship today. Details
This wireless HDMI extender lets you extend HDMI audio/video signal up to 328 ft. via 5 GHz band, with very low latency. It's ideal for point to point signal extension situations that require high quality HDMI video in a location where running cable is difficult or impossible. A built-in inferred extender enables the user to remotely control the source with its original remote at the display's location. This kit includes two short IR cables that enable you to keep the two wireless boxes out of sight.
Note: When adding extra receivers, follow the troubleshooting guide line-by-line. You must use the included 3.5 mm cable. Do not connect power to the transmitter or receiver until all other cables are attached. You must press reset on the transmitter and receiver exactly at the same time when instructed. If any of the four receivers stop receiving, power cycle it. Allow two to three minutes after pairing or power cycling for the picture to appear.
Specifications: • Transmit frequency: 5 GHz • Wireless extension distance without obstruction: 328 ft. (100m) • Power requirements: 5 VDC @ 1A • Output resolution: Up to 1080p 60 Hz, depending on input resolution • Audio sampling rate: Up to 48 kHz • IR frequency range 20 - 60,000 Hz • Chassis material: Metal • Dimensions: 5.12" W x 3.94" D x 1" H (130 x 100 x 25.5 mm).
Part Number88-184-452
Weight2.35
