  • RESTOCKED FaitalPRO 18XL1600 18" Neodymium Professional Subwoofer 8 Ohm
CLEARANCE RESTOCKED FaitalPRO 18XL1600 18" Neodymium Professional Subwoofer 8 Ohm
FaitalPRO
Part #88-294-1313
FaitalPRO
Part #88-294-1313
Model: 18XL1600
What is Open Box?
Open Box Guarantee
No Risk, No Hassle
View It New
For a lightweight, high output 18" woofer with extended frequency response, choose FaitalPRO's neodymium-powered 18XL1600 subwoofer. Its 4" diameter voice coil offers up to 1,600 watts RMS power handling.
  • 1,600 watt power handling and just 26.9 pounds
  • Low distortion motor with three aluminum shorting rings
  • Over 12 mm of Xmax for deep bass reproduction
  • Custom cast aluminum frame
  • Made in Italy
CLEARANCE $369.00
1In Stock
FaitalPRO's 18XL1600 18" professional subwoofer packs 1,600 watts of RMS power handling into a package that weighs less than 27 pounds, thanks to a neodymium motor and 4" diameter voice coil on a glass fiber former. A cast aluminum eight-spoke frame reduces rear reflections and increases basket strength, while the triple roll treated polycotton surround maintains linearity during heavy excursion.
For an extended frequency response and reduced distortion, the 18XL1600 employs three separate aluminum demodulation rings within the motor to reduce inductance down to a low 1.45 mH. 12.9 mm of Xmax on tap allows you to use this woofer in vented cabinets that are tuned very low. Made in Italy.
BrandFaitalPRO
Model18XL1600
Part Number88-294-1313
Weight30.65
