CLEARANCE RESTOCKED B&C 15SW115-4 15" Professional Neodymium Subwoofer 4 Ohm
All Open Box and Refurbished/Restocked products are 100% covered by the Parts Express 60 Day No-Hassle Returns Policy. Order risk free and take up to 60 days to check it out. If any Open Box item does not meet your standards simply return it within 60 days for a full refund.
View This Item NewB&C's 15SW115-4 15" pro subwoofer speaker boasts an oversized 4.5" voice coil, neodymium motor, 1,700 watts RMS power handling capacity, and 13.5 mm Xmax (60 mm peak-to-peak excursion before damage).
- Lightweight but powerful FEA-optimized neodymium magnet
- Extremely high BL factor and Xmax for outstanding LF output
- 13.5 mm Xmax, 60 mm peak-to-peak excursion before damage
- 4.5" split winding copper voice coil on fiberglass former
- Ventilated voice coil gap reduces power compression
- Aluminum demodulation ring on pole piece reduces distortion
- Double silicone spider
CLEARANCE $501.00
1 In Stock
We'll send you an email when RESTOCKED B&C 15SW115-4 15" Professional Neodymium Subwoofer 4 Ohm is back in stock or available for preorder.
