  • REFURBISHED Dayton Audio SA1000 Subwoofer Amplifier Rack Mountable
CLEARANCE REFURBISHED Dayton Audio SA1000 Subwoofer Amplifier Rack Mountable
Read 5 Reviews or
Dayton Audio
Part #88-300-811
Dayton Audio
Part #88-300-811
Model: SA1000
Read 5 Reviews or
What is Open Box?
Open Box Guarantee
No Risk, No Hassle
View It New
Dayton Audio's SA1000 mono subwoofer amplifier provides nearly a kilowatt of clean, solid power to your home theater or music playback system. The amp's convenient freestanding or rack-mountable configurations make it an ideal partner for high-performance subwoofer speaker systems.
  • Patented tracking down-converter power supply for high efficiency
  • Class-AB output stage for clean, controlled amplification
  • Low frequency parametric EQ allows you to boost or cut to custom-tailor the sound
  • Sophisticated soft clip circuitry improves headroom and protects woofers
  • Manual, auto, or triggered on/off for integration into any automated system
  • Switchable subsonic and bass boost filters
  • High pass output for looping signal back into distributed audio systems
CLEARANCE $322.00
MSRP: $549.99
Save $227.99 (41%)
Order in the next 0 hr 58 min to ship today. Details
17In Stock
The Dayton Audio SA1000 is a freestanding, high-power subwoofer amplifier designed for the DIYer, installer, and systems integrator. This unique monaural audio device delivers the raw power of a pro-sound amp, but with the features and flexibility of a dedicated subwoofer amplifier. It can be configured for stacking with other audio components, and includes removable ears for mounting in standard audio racks (2RU). The SA1000's patented tracking down-converter power supply ensures headroom for instantaneous power needs and the amp stays cool, thanks to its high-efficiency design.
A Class-AB amplifier configuration provides the SA1000 with clean and controlled output. From an application standpoint, the SA1000's low frequency parametric EQ enables you to boost or cut to custom-tailor the sound to suit the listening environment. Sophisticated soft clip circuitry provides cleaner transient peaks while protecting your driver from over-excursion. The amp's switchable subsonic filter removes subsonic information from the signal, which tightens the low end response of some subwoofer systems. On-board bass boost filters enhance LF performance while leaving the parametric EQ function available to address room modes, like cutting an excessively loud room resonance. The high-pass outputs provide a user the option to feed the signal back into their other audio components or a distributed audio system.
Manual, automatic on/off or triggered 12V input modes allow easy integration into automated systems. The stealthy pop-out knobs on the front panel make adjustments easy, while minimizing the risk of accidental disturbance. The SA1000's subdued brushed black aluminum faceplate allows the amp to blend cosmetically with any type of audio gear. Accommodates RCA line-level inputs, includes insulated binding posts for the speaker outputs, and accepts a 12V trigger via a 3.5 mm mini-jack.
Specifications: • Rated power output (0.92% THD): 497 watts into 8 ohms, 950 watts into 4 ohms • Signal to noise ratio: 98 dB A-weighted • Efficiency: 86% • Input impedance: 12K ohms • Subsonic filter: -3 dB @ 18 Hz, Q=0.8 • Bass boost: +3 dB @ 25 Hz, Q=1.4 • High pass output: -3 dB @ 80 Hz, 12 dB/octave • Low pass adjustment: 30-200 Hz • Phase adjustment: 0°–180° • Parametric EQ frequency: 18–80 Hz • Bandwidth: 0.1–1.0 Q • Level: -14.5 dB to +6 dB • Dimensions: 17-1/2" W x 4" H x 13" D (tabletop configuration) • Power requirements: 120/230 VAC, 60/50 Hz • Stand-by power rating: 120V 24W; 230V 18.4W • Weight: 28 lbs. • Power rating based on one-third power duty cycle.
ModelSA1000
Part Number88-300-811
Weight30.8
